Problems applying the right amount of Solder Paste
by jamesbuchanan1220 on Tue Feb 16, 2016 8:27 pm
As you can see from these photos, I'm having a hard time applying solder to pads for QFN parts with 0.5mm and below pad sizes. The stencil is 5mm thick, hence the pile.
If I were to placed a component on these pads and use my re-flow oven, I will surly get bridging.
And help would be greatly appreciated.
jamesbuchanan1220
Re: Problems applying the right amount of Solder Paste
by franklin97355 on Sun Feb 28, 2016 1:05 am
Not a lot you can change if you can't get the proper stencil.
franklin97355
by jamesbuchanan1220 on Sun Feb 28, 2016 12:31 pm
What is the proper stencil?
jamesbuchanan1220
by franklin97355 on Sun Feb 28, 2016 1:34 pm
One that has the proper thickness for the pitch of the pads on the PCB.
franklin97355
by jamesbuchanan1220 on Sun Feb 28, 2016 8:27 pm
This is the thickness suggested. There must be something else.
jamesbuchanan1220
by franklin97355 on Sun Feb 28, 2016 8:42 pm
Then you are not holding the stencil to the board tight or squeegeeing hard enough.
franklin97355
by jamesbuchanan1220 on Sun Feb 28, 2016 8:50 pm
Notice the surrounding pads, you'll see that this problem does not happen to the other pads. Have you ever used a stencil?
jamesbuchanan1220
by jamesbuchanan1220 on Sun Feb 28, 2016 8:59 pm
To be fair, these pads are associated to DFN type parts. Thus, less than 1 mm on each pads dimensions and from the configuration of the pads, not possible to hand solder; since the pads are under the part's body.
jamesbuchanan1220
by franklin97355 on Sun Feb 28, 2016 9:07 pm
I'm out of ideas then.
franklin97355
by juku on Fri Mar 18, 2016 7:03 am
SMD stencils are typically 0.1mm thick.
juku
by jamesbuchanan1220 on Fri Mar 18, 2016 2:52 pm
Where do you get 0.1mm thick stencils?
jamesbuchanan1220
by adafruit_support_mike on Sun Mar 20, 2016 11:05 pm
There are several companies online that will make them for you, but they run about $30-$40 per stencil.
by jamesbuchanan1220 on Mon Mar 21, 2016 3:52 pm
So far, only 3mil is available. Again, which company does less then 1mm?
jamesbuchanan1220
by juku on Mon Mar 21, 2016 8:44 pm
juku
by jamesbuchanan1220 on Tue Mar 22, 2016 2:21 pm
Thank you, I'll look into them.
jamesbuchanan1220
