IBDAP-CMSIS issues
IBDAP-CMSIS issues
by daguro on Tue Apr 25, 2017 6:48 pm
I just got one of these from Adafruit.
The armstart.com and armstart.co web sites seem to be off line. The only documentation is a two page PDF that isn't very complete.
When I plugged this into my Linux machine, it showed up with lsusb.
When I plugged it into my Windows 10 machine, it showed up as an HID USB device with an ID string that said something about "vendor".
It did not show up as an IBDAP-LPC11U35 CMSIS-DAP or anything like that.
On both computers, I could press and release both switches and get a USB MSC with a single file, firmware.bin.
The binary on Amazon AWS seems to be gone. I downloaded the source from github and built it. It is around 8k. I copied the code, per the instructions, and now it no longer shows up on my Linux machine when I run lsusb.
I can still press both switches and get a USB MSC with a single file, firmware.bin.
Does anyone have a binary file that is known to work?
What happened to the company that made this?
Are there more directions for this debug board?
daguro
Re: IBDAP-CMSIS issues
by daguro on Tue Apr 25, 2017 9:00 pm
It looks like the company behind this thing is no longer in business.
The company did a kickstarter thing, wicam, and it looks like they never delivered. Was this a kickstarter also?
Adafruit should not be selling it.
daguro
by adafruit2 on Wed Apr 26, 2017 11:08 am
huh thats odd, we were just chatting with them to place a new order a few weeks ago. this wasnt a kickstarter that we know of, we have been carrying it for a year and a half, https://blog.adafruit.com/2015/10/16/ne ... apter-kit/
their github repo is still up @ https://github.com/Armstart-com/IBDAP-CMSIS-DAP
the IBDAP is really nice as a CMSIS device, and should work. we'll contact them to see whats up - hopefully they will reply! :)
adafruit2
Site Admin
by daguro on Fri May 26, 2017 11:07 am
It has been a month since posting.
The IBDAP-CMSIS I purchased still doesn't work.
Is there anything happening with this?
daguro
by adafruit2 on Fri May 26, 2017 12:51 pm
hiya, we haven't gotten a response. if you can't use it email support@adafruit for a refund or credit. we suggest a jlink - they work great!
adafruit2
Site Admin
by DanaK6JQ on Thu Jun 15, 2017 2:45 pm
Looks like Armstart's domain and GitHub went dark rather suddenly, though there's still a Tindie page.
The good news, for me at least, is that my IBDAP works great with an STM32/SW4STM set-up. I just tweaked the debugger config file to use 'interface cmsis-dap' and 'transport select swd' and away it went. Attached is a current project using the IBDAP with an STM32F030K6 on a protoboard.
I did not need to update the firmware on the IBDAP.
Edit: here's a sample debug config file I'm using with SW4STM:
# This is an BC-Rock-10 board with a single STM32F030K6Tx chip
# Generated by System Workbench for STM32
# Take care that such file, as generated, may be overridden without any early notice. Please have a look to debug launch configuration setup(s)
interface cmsis-dap
set WORKAREASIZE 0x1000
set CHIPNAME STM32F030K6Tx
# Enable debug when in low power modes
set ENABLE_LOW_POWER 1
# Stop Watchdog counters when halt
set STOP_WATCHDOG 1
# STlink Debug clock frequency
set CLOCK_FREQ 4000
# use hardware reset, connect under reset
# connect_assert_srst needed if low power mode application running (WFI...)
reset_config srst_only srst_nogate srst_push_pull connect_assert_srst
set CONNECT_UNDER_RESET 1
source [find target/stm32f0x.cfg]
You also need to set the debug configuration to use this file rather than auto-generate it.
Cheers,
Dana
DanaK6JQ
by PurpleHaze on Sat Jul 01, 2017 4:36 pm
This is affecting me as well. I got a IBDAP adapter so that I could start flashing on my Laird eval kit (DVK-BL652_1.0) via Keil.
Finally got around to plugging it in, and the board shows up as "CRP_DISABLED". That's weird... I'll update the firmware...
Website domain gone
GitHub has a 404 error
..great. Looks like these guys either packed up or they need to fire their web admin.
If anyone has some other suggestions on how to debug using this kit, I would also appreciate it. Right now I have a little blue LED and that's about it.
PurpleHaze
by franklin97355 on Sun Jul 02, 2017 1:01 pm
Send a note containing a link to this thread and your order number to support@adafruit.com. The folks there will help you arrange a return and store credit.
franklin97355
by lvd on Sat Mar 24, 2018 8:52 am
Same problem for me,I just ordered the IBDAP...
But I found another github which might contain what we need:
https://github.com/devanlai/IBDAP-CMSIS-DAP
I'll try it out when my order arrives.
Ok, it arrived & it works.
When I connect it it shows up as a USB Disk Drive with the firmware.bin in it.
But when I press once the RST_SW it goes to CMSIS-DAP mode.
After some looking up how to configure openocd I finally can debug my Arduino due!
lvd
by jkpdx on Wed Apr 11, 2018 6:30 pm
I just got one of these and couldn't get it to work with Rowley. But I re-flashed using the LPC1768 pre-built image from https://os.mbed.com/platforms/SWDAP-LPC11U35/ and now it works fine. Agree Adafruit probably shouldn't be selling these with so little support.
jkpdx
