Blown 200mA fuse on DT-9205B+ Multimeter
by DonMan8848 on Tue May 15, 2018 3:49 pm
Well, I goofed... I used the 200mA leads when I should've used the 20A leads. Zapped my ammeter with a little over an amp of inrush current testing a 120V AC solenoid valve.
Anyway, the rest of the multimeter functions, including the 20A leads, work just fine. Seems I just blew the fuse in the 200mA circuit, since it behaves like an open circuit now. Does Adafruit sell replacement fuses, or should I just get a whole new meter?
(Post title edited for typo)
DonMan8848
Re: Blown 200mA fuse on DT-9205B+ Multimeter
by adafruit_support_mike on Tue May 15, 2018 11:10 pm
You shouldn't need a new meter, just a new fuse. Unfortunately we don't carry them.
Mouser or Digikey will have what you need though. Could you post a photo showing the one that blew and we'll see if we can hook you up with the right part. 800x600 images usually work best.
by DonMan8848 on Wed May 16, 2018 11:20 am
I believe it's the one labeled "FU1," in the center near the 200mA and ground pins.
Blown Fuse Image
DonMan8848
by adafruit_support_mike on Wed May 16, 2018 11:01 pm
Thank you.. that looks like a standard 5x20 package. This one should work as a replacement:
https://www.digikey.com/product-detail/ ... ND/1008993
