Extech EX330 current ranging issues
- bebo
I'm getting some results from the multimeter that seem wrong. When I switch between microamps and milliamps, the decimal point only shifts one place. A reading of 15 microamps reads as 1.5 milliamps when I switch the setting. That and the value seems totally off for a simple series resistor circuit. 9VDC and two 1K resistors in series should be 4.5 milliamps, correct? On the microamp setting, I can toggle the "range" button and get two different values, 13.3 and 40. What gives?
Re: Extech EX330 current ranging issues
Could you post a photo showing the connections you're using when you take the measurements please? 800x600 images usually work best.
- bebo
I'll get an image shortly, but when I made the same measurement with a different, lower quality meter, it reads 4.5mA just like it should.
- bebo
I have the meter attached between the 9V rail and the first 1K resistor. The Woods meter is in agreement with Ohm's law, the Extech not so much. If I switch to the 5V rail, the Woods reads 2.5 mA, and the Extech 1.7 mA.
- Attachments
- extech_04.jpg (135.12 KiB) Viewed 514 times
- extech_03.jpg (157.98 KiB) Viewed 514 times
- extech_02.jpg (159.36 KiB) Viewed 514 times
Thank you.. the circuit and connections look good.
Do you get weird values on any of the other settings?
