Larger Tip for Large Heat Inserts
by thetranq on Fri Jun 17, 2022 11:35 am
Hello All,
I recently made the Adafruit heat insert rig, and I purchased the "Adjustable 60W Pen-Style Soldering Iron - 120VAC USA Plug - BEST 102C" as the soldering iron. It works great for small heat inserts, but I tend to do larger heat inserts (for instance 1/4"-20 heat inserts) and the included tip is too small to do these very well.
Does anyone know if there are larger-diameter replacement tips for this soldering iron that would work for my application? On most of the tips I see on Adafruit, I cannot find the dimension of the largest part of the cone so I do not know which would be best.
Thanks in advanced
thetranq
Re: Larger Tip for Large Heat Inserts
by dastels on Fri Jun 17, 2022 11:42 am
I have no idea what 1/4"-20 means but there are tips in the Adafruit shop for M3 and M5 inserts. https://www.adafruit.com/product/4239 and https://www.adafruit.com/product/4249
dastels
by thetranq on Fri Jun 17, 2022 11:45 am
1/4"-20 is a standard SAE thread type. It is a little larger than 5mm
thetranq
by dastels on Fri Jun 17, 2022 11:49 am
The M5 tip may work fairly well, then.
dastels
by thetranq on Sat Jun 25, 2022 11:55 am
I ordered it and just got it. I can't actually seem to find a way to connect the new tip to the soldering iron?
thetranq
by dastels on Sat Jun 25, 2022 12:00 pm
What iron do you have? Note, on the insert tip page:
All you need is a soldering iron that takes Hakko tips (which nearly all the irons we stock do). I
dastels
by thetranq on Sat Jun 25, 2022 12:07 pm
I have the 'BEST" 60W iron.
https://www.adafruit.com/product/3685
thetranq
by dastels on Sat Jun 25, 2022 2:02 pm
Then you're good to go:
Best of all, you can use this iron with Hakko tips.
Unscrew the nut near the base of the heating element, slide the sleeve off and replace the tip by carefully pulling it off the heating element. Reverse the process with the new tip.
dastels
by thetranq on Thu Jun 30, 2022 2:36 pm
When I do that, the nut cannot get all the way back to the threads due to the tip getting stuck on the sleeve. I will send a short video shortly
thetranq
by thetranq on Thu Jun 30, 2022 3:01 pm
https://www.youtube.com/shorts/2CjGHYDd1us
You can see in this video what I mean. The large tip obstructs the sleeve and nut from reaching the threads, it seems that it is not compatible
thetranq
