Hello everyone!
I am looking for some PCB mount shrouded (safety) banana jacks that can stick through a panel from the rear. As in: you solder the jack onto a PCB, then put the pcb behind a panel and the jack sticks through the hole in the panel. Every multi-meter has this type of jack.
I took apart my multi-meters and they all have a swaged tube soldered to a pcb, with a plastic shroud around the tube. But I could not find any part numbers or logos.
Does anyone know where I could find a multi-meter style banana jack that will insert through a panel from the rear?
