How do you cut PCB?
How do you cut PCB?
by shobley on Wed Nov 11, 2009 7:34 pm
I just spent about 20 minutes trying to cut through a PCB with a hacksaw. These things are really tough.
What is the correct tool to cut PCB material, and get a nice straight line?
I saw something about a guillotine, but can't find a vendor.
Steve
http://www.stephenhobley.com
http://www.youtube.com/shobley
For all your laser harp, tesla coil, and killer robots from outer space needs.
shobley
Re: How do you cut PCB?
by adafruit on Wed Nov 11, 2009 7:42 pm
tin snips
by adshea on Wed Nov 11, 2009 8:00 pm
I agree on tin snips. Box cutter and a good straight edge works too for thin (<1/32) board.
adshea
by zener on Thu Nov 12, 2009 2:31 am
Jig saw or band saw works too.
zener
by trialex on Thu Nov 12, 2009 5:17 pm
This can suck hey.
There are a few different types of PCB material. FR4 is the most common, this is very difficult to cut with a hacksaw. FR4 is made up of glass fibre matrix held together with an epoxy resin
FR2 on the other hand is paper based with epoxy resin. I think this stuff is easier to cut.
Often the material isn't listed though, which sucks.
trialex
by westfw on Thu Nov 12, 2009 9:23 pm
I spend quite a bit of effort seeking thinner PCB stock... Once it's thin enough, a pair of those cheap heavy-duty penny-cutting scissors works pretty well. Electronics goldmine currently has something they're calling "scissors cut" copper clad, and ABCFAB on ebay regularly has SS stock less than 1/16....
westfw
by adshea on Mon Nov 16, 2009 11:19 pm
I've found this seller on eBay http://shop.ebay.com/amt33461/m.html?_nkw=&_armrs=1&_from=&_ipg= I haven't ordered any yet (still finishing up my printer for some direct inkjet mask stuff) but they seem a good place for thin stuff.
adshea
by minerva on Sun Dec 06, 2009 11:38 pm
I will assume that you're using something like FR4, the standard glass-fibre composite PCB material, and not that cheap paper and phenolic resin stuff.
Try scoring a thick line across it, (both sides if you wish) using some sort of scorer or sharp pointy tool, and then clamp it against the edge of a bench, and snap it or break it.
Then use sandpaper or a file to clean up the edge.
minerva
by rizla420 on Wed Dec 09, 2009 4:33 pm
Can paper cutters work as well for the FR4 or the heavier duty ones? I have some snips that i use for cutting steel sheets, i wonder if i should give that a shot.
rizla420
by ieeej on Sat Dec 12, 2009 6:20 am
Here's what I did the other day:
http://www.flickr.com/photos/ieeej/4177692921/
ieeej
by shobley on Sun Dec 13, 2009 11:01 pm
I bought a pair of reciprocating action tin snips from Home Depot and they really do the trick...
shobley
by adafruit_support_mike on Mon Feb 15, 2010 3:12 am
I have an old guillotine-style paper cutter (the kind with the square board and the big-honkin' blade). It cuts FR4 pretty well. It's not as good as an actual PCB shear, but it's there and it does the job.
by charliex on Mon Feb 15, 2010 2:09 pm
I've yet to find a cheap gullotine/shear, usually around $400-500 though i just cnc em now :)
$85 isn't terrible, and you can use it for other things like loosing fingers.
http://www.harborfreight.com/cpi/ctaf/D ... mber=90757
http://032.la - Null Space Labs.
charliex
by mojo on Tue Mar 09, 2010 10:21 am
I found a place that does matrixboard you can cut with scissors. I can't for the life of me remember the name now, but it's very useful for prototyping. If I remember I'll post a link when I get home next month.
mojo
by JRock on Fri Apr 16, 2010 10:23 pm
I'm a stone Mason by day. I had a hell of a time trying to score it and snap it or use a saw.
I ended up using my grinder with a masonry blade. It works perfect!
I imagine a wood blade on a power saw would splinter the crap out of a pcb but you can pick up Masonry/tile blades for them at the hardware store (the metal kind, I haven't used the carborundum, but they may work too.)
Cuts the copper pads too. Wear safety glasses though cause them tiny splinters are sharp! Probably wouldn't feel nice to catch a red hot copper solder pad in the eye either.
Once it's cut I can trim the sides up nice too.
JRock
