I'm very new to hardware hacking and I just got my starter kit for my Arduino. I also got a helping hands (with magnifier) but I noticed something about the cage:
I wanted to find out if having the tip of the soldering iron touching the protective cage was damaging while the iron was on. (see picture)
http://imgur.com/uGV6o
--B
Newbie question: Damaging the soldering tip?
- binarynomad
- zener
Re: Newbie question: Damaging the soldering tip?
That looks fine to me. That is not the tip anyway, that is the side of the tip!! No problem.
- binarynomad
Zener,
Thanks for letting me know. I just wanted to be safe about it (especially with my first iron ).
- Franklin97355
The only problem I see is the fact that you are pulling the heat out of the tip when it touches. If you wait a few seconds before soldering your iron should rebound but it might not take much to move the touch point further up the iron.
Yeah, the protective cage is a big heat sink for the tip of your iron.
Is the cage get hot enough to burn somebody if they touch it?
- binarynomad
Yeah, the cage does get quite hot (not as bad as the iron), but enough for me to be wary of it. I'm wondering if I need to jerry-rig something.
I would fix it if I were you.
