Choosing Solder
Choosing Solder
by jonfen on Sun Feb 07, 2010 5:41 pm
What solder should I be using?
I just watched a 40 minute IPC video on "Hand Soldering for Through Hole Components (Tin-Lead Solder)" and it brought up some questions for me.
To spare you from watching the whole video. They made the point that 63/37 eutectic solder doesn't have a "plastic range" that 60/40 does, they also made the point that 63/73 turns liquid at a lower temperature -- which means less heat required and thus less chance of damaging a component.
They also recommend using a solder thinkness that is slightly less than half the size of the land you are soldering.
So what are the reasons for choosing 60/40 solder over 63/37 eutectic solder mentioned in the SpokePOV parts list?
Sincerely,
Jonathan Morrison
Co-Owner
OpenSprints LLC
c: 801-688-0183
w: 801-784-8566
f: 801-606-7568
http://www.opensprints.org
jonfen
Re: Choosing Solder
by westfw on Sun Feb 07, 2010 6:59 pm
63/37 solder is somewhat less common than 60/40. For example, All Electronics, referenced for most of the tools in that Parts List, doesn't sell 63/37. If you have a source, it's fine to use, and probably even preferred. But it's not "necessary."
westfw
Re: Choosing Solder
by Rotzog on Sun Feb 07, 2010 8:03 pm
I use Kester 60/40 .031 inch for most things, and .050 for larger parts.
Just a personal reference though, developed the years.
Try different sizes and types (both brands and mixes) -- you will develop your own preferences.
Rotzog
