Soldering Iron temp setting for screw inserts
by wsquared58 on Thu Sep 12, 2019 9:58 pm
I have a HAKKA soldering iron with adjustable temperature setpoint and was wondering what is a good starting temperature to set the iron to?
wsquared58
Re: Soldering Iron temp setting for screw inserts
by franklin97355 on Thu Sep 12, 2019 11:19 pm
I'll check.
franklin97355
by pixil3d on Fri Sep 13, 2019 11:35 pm
For PLA around 190C / 374F should work.
pixil3d
by wsquared58 on Mon Sep 16, 2019 7:40 am
Different plastics end up having significantly different melting properties. Polycarbonate enclosure temp I used was 465 which made it soft and deformable but still required a little force to push in which was good because it was much easier to keep the insert correctly aligned.
Related to that, the inserts have a narrow center section and I measured that diameter with calipers and used a drill bit to drill out plastic bosses to that diameter. If you don't do that the plastic will push up in to the threaded part of the insert rendering it useless.
wsquared58
