To Support: Issue with 1 x Digital Multimeter - Model 9205B+
by jhughes504 on Thu Jan 23, 2020 3:46 pm
Screen Shot 2020-01-23 at 2.34.23 PM.png (1002.53 KiB) Viewed 120 times
Hi there,
I'm writing because now that I've put a battery in the multimeter (the one with the blue rubber casing DT-9205B) the numbers don't seem to be reading correctly at all. I'm just looking at it for the first time and turning the knob and the numbers are off - the 6 for example is missing a horizontal mark (photo attached). I am actually new to this so am not sure if I'm just inexperienced but if this isn't normal can I exchange it or return it?
Thanks,
James
jhughes504
Re: To Support: Issue with 1 x Digital Multimeter - Model 92
by adafruit_support_carter on Thu Jan 23, 2020 7:26 pm
Go ahead and insert the probes and try making a measurement. Do you have some resistors or something you could use for a resistance check? Or maybe a battery for a voltage measurement?
