Soldering Iron Tips Not Melting the Solder
- alphagenius
I am using a Hakko FX-888D soldering iron. I am having difficulty in getting my iron to melt the solder which includes tinning it. I have the problem with previously used tips and now I am using a new tip. The only way to get the solder to melt is to touch it to a place up from the tip. I am hoping that someone can help me with this issue.
- dastels
Re: Soldering Iron Tips Not Melting the Solder
A couple things come to mind.
What is the temperature set to? Wortyh asking, but since it melts further up I suspect that's fine.
Have a look at the heating element. Remove the tip and sleeve. Is the end broken off? Or cracked?
- adafruit_support_carter
Does sound like something maybe internal. Good idea about removing the tip and checking the heating element. Anything obvious there?
