I am looking to use the following product from TI
https://www.ti.com/lit/ds/symlink/pth08 ... PTH08T241W
On page 36, the datasheet shows that the through-hole version has pin pitch of 0.125". I found this product from Adafruit that seems to have the required pin pitch
https://www.adafruit.com/product/571#description
Its description shows "2 x 0.125" or 3.2mm mounting holes 2.9" apart". I am not quite sure what this means. Can someone please help me confirm that these proto boards can fit the 0.125" pitch required by the TI product? Thanks in advance.
Regards,
Lu
PERMA-PROTO HALF-SIZED BREADBOARD PCB Pitch
Re: PERMA-PROTO HALF-SIZED BREADBOARD PCB Pitch
Those are the mounting holes for the board. 0.125" is the diameter of the mounting hole - not the spacing.Its description shows "2 x 0.125" or 3.2mm mounting holes 2.9" apart".
The through-plated holes in the prototyping grid are spaced at a 0.1" pitch.
