ES120 screw driver
Re: ES120 screw driver
by adafruit2 on Sun Apr 04, 2021 5:20 pm
have you sent the video to miniwave and asked for support help? we don't have any access to the firmware, we really just sell the screwdriver!
adafruit2
Site Admin
by zmilewski on Sun Apr 04, 2021 9:27 pm
adafruit2 wrote:have you sent the video to miniwave and asked for support help?
I just did, and will report back here if they respond. Thanks for the object lesson in how to annoy your (former) customers.
zmilewski
by zmilewski on Mon Apr 05, 2021 10:50 pm
Miniware responded, asked for a receipt and serial number, and are sending a replacement under warranty.
zmilewski
by zmilewski on Tue Apr 06, 2021 2:19 pm
In the mean time, I ordered one from Amazon, which I seem to be able to operate just fine. I'll let you know if I can successfully operate the replacement from Miniware when it arrives.
zmilewski
by zmilewski on Tue Apr 20, 2021 3:51 pm
The replacement arrived from Miniware today, and apparently I have enough practice to operate this one as well.
So, it's just the one that Adafruit shipped that I'm not skilled enough to operate. Or, perhaps, Adafruit got a bad batch, and @adafruit2 should stop blaming the customer.
zmilewski
by quilltrott on Tue Apr 20, 2021 11:32 pm
Wow!! I got mine in from Amazon last week and I too must have some how acquired the needed skill to correctly operate this devilishly confounding tool. Maybe the Ada fruit ones are more complicated??? I’m sure there’s a reasonable explanation.
quilltrott
by Machman on Wed Jul 07, 2021 9:38 am
I am having the exact same issue, it seems like it's an issue with voltage sag causing instability, combined with a low voltage and overcurrent protection triggering. If so, it is a hardware problem, and no firmware is going to fix it.
If someone is feeling adventurous, maybe try replacing the battery with something a bit bigger like an 18650 with an extended case, that might fix the issue, at the cost of warranty and the possibility of a return.
Machman
