ES120 screw driver
Hand tools, soldering irons, scopes, multimeters. Talk about em HERE!
adafruit2
Re: ES120 screw driver
Post by adafruit2 »
have you sent the video to miniwave and asked for support help? we don't have any access to the firmware, we really just sell the screwdriver!
zmilewski
Post by zmilewski »
adafruit2 wrote:have you sent the video to miniwave and asked for support help?
I just did, and will report back here if they respond. Thanks for the object lesson in how to annoy your (former) customers.
zmilewski
Post by zmilewski »
Miniware responded, asked for a receipt and serial number, and are sending a replacement under warranty.
zmilewski
Post by zmilewski »
In the mean time, I ordered one from Amazon, which I seem to be able to operate just fine. I'll let you know if I can successfully operate the replacement from Miniware when it arrives.
zmilewski
Post by zmilewski »
The replacement arrived from Miniware today, and apparently I have enough practice to operate this one as well.
So, it's just the one that Adafruit shipped that I'm not skilled enough to operate. Or, perhaps, Adafruit got a bad batch, and @adafruit2 should stop blaming the customer.
quilltrott
Post by quilltrott »
Wow!! I got mine in from Amazon last week and I too must have some how acquired the needed skill to correctly operate this devilishly confounding tool. Maybe the Ada fruit ones are more complicated??? I’m sure there’s a reasonable explanation.
Machman
Post by Machman »
I am having the exact same issue, it seems like it's an issue with voltage sag causing instability, combined with a low voltage and overcurrent protection triggering. If so, it is a hardware problem, and no firmware is going to fix it.
If someone is feeling adventurous, maybe try replacing the battery with something a bit bigger like an 18650 with an extended case, that might fix the issue, at the cost of warranty and the possibility of a return.
Return to “Tools Tools Tools”
