TS80P PID:4244
Hand tools, soldering irons, scopes, multimeters. Talk about em HERE!
DaveDice
TS80P PID:4244
Post by DaveDice »
I just received a TS80P soldering iron. Interestingly, the seals on the box were broken, btw. When I power it up, it just loops and resets when I try to set the temperature. It also never heats up. If I connect to a Macbook pro USB-C power supply (also using the supplied cable from the box), then it appears to work correctly, so I'd like to arrange for a replacement.
Thanks, -Dave
Order number # 2567862-3090503097
mikeysklar
Re: TS80P PID:4244
Post by mikeysklar »
Would you mind booting up the iron and letting us know the firmware number. You could upgrade it yourself, but since the box was open and the iron is not working I don't expect you to do that. Just curious what the shipping firmware is as the current release is v1.0.7. it should say the firmware version upon startup.
http://www.minidso.com/forum.php?mod=vi ... d&tid=3208
Also the iron appears to prefer 9v @ 2A power supplies according to their PDF. There is a mention about resetting due to power supply issues in the troubleshooting guide.
DaveDice
Re: TS80P PID:4244
Post by DaveDice »
This is the TS80P, and it reports version 1.27 when it boots up. I'm using the USB-C power supply that was boxed with the soldering iron.
Regards, -Dave
mikeysklar
Re: TS80P PID:4244
@DaveDice,
Let's try a replacement. Please e-mail [email protected] with your order# and request a replacement for the TS80P iron. Be sure to include a link to this forum thread. Let us know if you have any issues with the replacement.
DaveDice
Re: TS80P PID:4244
Post by DaveDice »
Thanks, will do
Return to “Tools Tools Tools”
