I got an ES120 recently. It worked the first day, but then I went to use it the next day and it wouldn't turn on. Black screen. I pushed the button, I held the button, nothing. I plugged it in to charge, thinking maybe the battery was low. The screen turned right on and charged okay. After charging I test it and it worked again. But then the next day I went to use it and same problem, won't turn on.
Honestly from the two times it did work it didn't seem to work very well at all anyway. Wondering if maybe I can just return and refund it?
Thanks.
ES120 Not Working
- mikeysklar
Re: ES120 Not Working
@nand,
There is a firmware update if you want to give it a try. It is supposed to adjust the "flaky screen" scenario.
http://www.minidso.com/forum.php?mod=vi ... d&tid=1733
You can return it to us for a refund or contact the vendor to ask what's up with this unit e-mail: [email protected]
