DT-9205B Digital Multimeter problem
by davidleejones on Wed Apr 01, 2015 5:02 pm
I purchased the Ladyada Toolkit and am just now trying to use the digital multimeter. It seems to be defective. When trying to measure voltage for example, even with leads not touchning anything, the display value floats around randomly. When connected to say a AA battery, it goes to -0.00.
I have tried various settings, @ Volts, 20 Volts etc and nothing works.
My cheap $4 meter from Harbor Freight reads just fine.
The black lead is connected to COM, second from right and the red lead is connected to V, 1st one on right.
Any ideas or do I need to exchange it?
David
davidleejones
Re: DT-9205B Digital Multimeter problem
by adafruit_support_mike on Wed Apr 01, 2015 7:04 pm
Try putting a new battery into it. If the behavior remains the same, post back and we'll see what else we can find.
by keithfiore on Tue Jul 21, 2015 5:53 pm
David,
Any updates regarding your multimeter issue?
keithfiore
by neilly on Thu Sep 22, 2016 5:17 pm
I too have had some problems with either the multimeter or the instructions in the box.
1. I had to discover the on/off button..
2. The continuity check instructions did not seem to agree with the meter.There was no choice on the rotary switch for the alternative listed in the instructions
3. Some functions couldn't be found: frequency, temperature,...
neilly
by adafruit_support_mike on Fri Sep 23, 2016 2:49 am
Unfortunately, the companies that make low-cost multimeters aren't very diligent about updating their documentation.
