Which crimp tool?
Which crimp tool?
by Astounding on Fri Jun 12, 2015 11:15 am
I see adafruit sells the PA-09, PA-20, and PA-21 crimp tools from
Engineer. I'm very confused which tool is the proper one for my purposes. I
will mostly be crimping 2.54mm "dupont" breadboard style jumper connectors.
Which tool would do this job well and also have versatility for other connectors? I may be getting into RC in the
near future. I'm also curious if the blue ratcheting style crimpers would
perform better or worse?
Astounding
Re: Which crimp tool?
by adafruit_support_mike on Fri Jun 12, 2015 6:27 pm
What size wire are you using? It's usually easier to convert that to the size of a crimp die.
by Astounding on Sat Jun 13, 2015 9:44 am
I'll be using 24 awg wire. Can the PA-09 crimp standard breadboard header pin connectors as well as the ultra mini RC stuff? I was having some trouble understanding the die charts. I'm also not sure what these connectors I'm crimping are officially called. I see them called "dupont" around the web.
Astounding
by adafruit_support_bill on Sat Jun 13, 2015 9:53 am
The PA-09 is probably the bet match for what you are doing. Most common breadboard jumpers are 22-24 awg, so they can be handled by that crimper also.
by UPWPFAN on Wed Nov 02, 2016 4:02 pm
Folks
I am trying to crimp 26 to 30 AWG wire onto HIROSE DF 13-2630SCF connectors (see attachment) which crimper in your catalog would you recomend?
Regards
UPWPFAN
DF13_05360300500_2d.pdf
(107.89 KiB) Downloaded 87 times
UPWPFAN
by adafruit_support_bill on Wed Nov 02, 2016 4:21 pm
I haven't worked with those specific connectors, but based on the dimensions in the drawing, the PA-09 should be the best fit.
https://www.adafruit.com/products/350
