Hot Air Soldering Rework Station Fan turns off
by jcarlisle on Tue Jun 14, 2016 10:40 am
We ordered a hot-air rework station in April and it has begun acting a bit finicky. After about a minute of use, the the fan turns off and airflow stops. We have tried various combination of returning the nozzle to its stand, power cycling the station, but nothing seems to make it consistently functional. It appears to arbitrarily alternate between a functioning and non-functioning state.
Product: Hot Air Soldering Rework Station w/ Three Nozzles - Quick 957D PRODUCT ID: 1869
Order #1069723-8322305710
jcarlisle
Re: Hot Air Soldering Rework Station Fan turns off
by adafruit_support_mike on Sun Jun 19, 2016 12:22 am
It sounds like the thermal cutoff is kicking in. What temperature setting are you using, and which tip?
by jcarlisle on Mon Jun 20, 2016 4:24 pm
Most recent settings are 275°C using the largest tip.
If that was the case, why would the fan shut off? Shouldn't it stay on to cool the station?
jcarlisle
by adafruit_support_mike on Wed Jun 22, 2016 3:01 am
We didn't write the firmware, and I can't answer for the people who did. That combination of temperature and airflow isn't likely to overheat anything though.
Try unplugging the unit and letting it sit without power over a weekend. We've seen a small number of those units get stuck with what seems to be an incorrect register setting or something. Disconnecting power long enough to make everything settle back to initial-power-up state seems to solve the problem.
by jcarlisle on Mon Aug 08, 2016 10:53 am
Hadn't used it in over a month. Turned it back on today, and it displayed the same symptoms. What next?
jcarlisle
by adafruit_support_mike on Wed Aug 10, 2016 2:11 am
Send a note containing a link to this thread and your order number to support@adafruit.com. The folks there will get you a replacement.
by Muntygoesbad on Fri Sep 30, 2016 2:32 pm
I ordered the Hot Air Soldering Rework Station w/ Three Nozzles - Quick 957D on September 3rd 2016. On the 29th of September 2016 the rework station stopped blowing altogether and it seamed that it wasn't heating up either.
Order# 1203406-5959093700
Down below is a picture of what happens when it is on.
Muntygoesbad
by adafruit_support_mike on Sat Oct 01, 2016 12:36 am
Try disconnecting power for a couple of days.
There seem to be times when bad information gets written to the internal memory. Disconnecting power long enough to dissipate any stored charge usually lets the machine start in its default state again.
by Muntygoesbad on Sat Oct 01, 2016 11:44 pm
I have decided that I will be shipping the product back. I cannot have equipment that has the ability to choose when to work and when not to work. If that was the case nothing over here would get done.
I still have the original box that it came in so I will be packing it up today.
Muntygoesbad
