Soldering Construction Question
by j_schultz on Fri Jun 17, 2016 3:20 pm
I am using a 3V pro-trinket with the Li-Poly rechargeable backpack. I need to solder a string of LEDs to the 5V pin and the ground pin that the Li-Poly backpack uses as well. What is the best way to make this connection? I am currently using the method described in this tutorial:
https://learn.adafruit.com/crystal-glow ... to-trinket
Is there a more reliable junction I can make or is this fine if the wires don't move?
Thank you.
j_schultz
Re: Soldering Construction Question
by adafruit_support_bill on Fri Jun 17, 2016 3:33 pm
That is not going to work. The 5v pin only has 5v when the backpack is plugged into USB. The tutorial has you connect the +5v pin of the Neopixels to the BAT+ pin of the Trinket. https://learn.adafruit.com/crystal-glow ... -the-board
On the backpack, there are two holes next to the 5v pin that are linked together. These two holes are also connected to BAT+, so they would be an easy place to solder your pixel connections.
by j_schultz on Fri Jun 17, 2016 3:43 pm
Okay thank you.
Secondary question, what is the best way to fasten down a one of the lithium ion batteries. Is hot glue safe to use?
j_schultz
by adafruit_support_bill on Sat Jun 18, 2016 6:05 am
I don't like using hot glue on LiPo cells. double-sided foam mounting tape is my preferred method.
