Re: receiver parts are inoperable and do not work
by adafruit_support_mike on Fri Jul 01, 2016 12:56 am
We'll replace or refund if we can verify a hardware or production failure.
I have due diligence to perform though. A hardware failure rate of 50% is far higher than normal for those devices, and assuming we do confirm it, is a matter we'll have to take up with the manufacturer. The first thing they'll ask for is a description of the operating conditions, so I need to make sure the boards were connected and powered in a way consistent with the published specs.
I accept your statement that the chips overheated, but can think of a dozen ways to cook one by connecting it to voltages outside its safe working range. In my experience diagnosing failed hardware, about 90% of hot chips trace back to that cause. I need to rule that out for these boards.
Please have your engineers provide a photo showing a board connected the same way as the ones that failed, plus a description of the supply voltage and any signals connected to the board. 800x600 images usually work best.
WRT the board with low transmission distance, that's an issue we do know. I can authorize replacement or refund for that one without any further questions.
