Black Lives Matter - Action and Equality.
out of stock of some parts
by otaola on Sun Mar 27, 2016 6:43 pm
hello,
i am starting a new project and i need to know if the things in out of stock are going to be in stock or they are things that adafruit its not selling any more.
in my case i am needing this two things.
https://www.adafruit.com/products/805
https://www.adafruit.com/products/913
i put to recive a mail when they are in stock but i couldnt find any information of when it is going to be in stock or even if its going to be in the future.
i tried to use the contact part but the page keeps freezing.
otaola
Re: out of stock of some parts
by franklin97355 on Sun Mar 27, 2016 8:03 pm
If it says out of stock we plan to carry it. otherwise it will say discontinued.
franklin97355
by Pinkstar14 on Thu May 05, 2016 7:27 pm
Hi I am also after out of stock items particularly Adafruit NeoPixel Digital RGBW LED Strip - White PCB 60 LED/m
Do you know how long before they will be in stock?
Wanting to make an order but would rather get everything all at once since shipping overseas.
Pinkstar14
by franklin97355 on Fri May 06, 2016 12:09 am
The black is in stock but not the white. Depending on the project you might want to get that instead. When it comes to re supply we are at the mercy of our suppliers and the whims of the gods so we tend not to give ETAs. If you can't use the black then sign up and be one of the first to be notified when it comes in.
franklin97355
by hojoe on Tue May 24, 2016 1:42 pm
hojoe, hello just received parts pal (2975) and I was wondering how I tell the values of the ceramic capacitors. They are marked 103, 104, and 105. Under capacitors only 1 link is available I assume that the other 2 values are out of stock. Can you tell how the values 103 through 105 relate to the capacitance? Thanks so much for your help.
hojoe
by franklin97355 on Tue May 24, 2016 3:44 pm
franklin97355
