Increase GPSD capture speed?
by jamiedixon on Tue Jul 11, 2017 12:31 pm
I am following the article found here: https://learn.adafruit.com/adafruit-ult ... g-your-gps
I am capturing the data at 1 second - the default
How can I capture at the fastest speed (which, I understand to be 10 MZ or 1/10 of a second)?
the GPSD api docs do not say AFAIK
jamiedixon
Re: Increase GPSD capture speed?
by adafruit_support_rick on Wed Jul 12, 2017 8:24 am
Don't know much about gpsd, but you can cat this command to the GPS to set it for 10Hz:
$PMTK300,100,0,0,0,0*2C
It needs a <cr><lf> at the end to be processed
by jamiedixon on Wed Jul 12, 2017 9:00 am
Yeah - I am searching their list serve (http://lists.nongnu.org/archive/cgi-bin ... sort=score) and someone else had the same issue
Looks like I can't tell the board to speed up the output via their api, so I either have to set it via the command line or figure out how to pass $PMTK300,100,0,0,0,0*2C somewhere in their api
I might make a pull request of an interface of setOutputSpeed(int) and have the 1 implementation that $PMTK300,100,0,0,0,0*2C can pass to the board.
jamiedixon
by adafruit_support_rick on Wed Jul 12, 2017 3:22 pm
Just use echo from the command line. As long as the backup battery is installed in the GPS, the setting will persist.
echo '$PMTK300,100,0,0,0,0*2C\r\n' > /dev/tty_AMA0
by jamiedixon on Wed Jul 12, 2017 3:25 pm
jamiedixon
cron
