📣📪 🚚 Adafruit will not be shipping USPS orders Monday January 20, 2020 🗓. Expedited USPS orders placed after 11am ET 🕚 Friday January 17 will go out Tuesday January 21 📣📪🚚
Adafruit Micro Lipo - USB LiIon/LiPoly charger
by ulianaapatina on Thu Dec 21, 2017 12:24 pm
Dear Adafruit,
Thank you so much for your products.
I have a question to ask:
The batteries arrived fully charged and the power lasted for a long time. Now they both run out of power. I plugged them into a charging port and left each of them for two days in. However, the power lasts only for several minutes :(
Could you please advice me on what I am doing wrong?
My order No: 1613657-4903921068
Items: 2 x Lithium Ion Polymer Battery - 3.7v 500mAh[ID:1578] = $15.90
1 x Adafruit Micro Lipo - USB LiIon/LiPoly charger (v1) [ID:1304] = $5.95
Many thank you,
Uli
ulianaapatina
Re: Adafruit Micro Lipo - USB LiIon/LiPoly charger
by franklin97355 on Thu Dec 21, 2017 2:43 pm
What do the charge and done lights do?
franklin97355
by ulianaapatina on Thu Dec 21, 2017 3:03 pm
there are no lights at all
ulianaapatina
by adafruit_support_mike on Fri Dec 22, 2017 3:18 am
What voltage do you see between the pins of the JST connector?
by adafruit2 on Fri Dec 22, 2017 3:02 pm
make sure you're pluggint the microlipo in correctly - when no battery is attached you should still see the red and green LED's dimly lit
adafruit2
Site Admin
by ulianaapatina on Wed Dec 27, 2017 6:36 am
3.7/4.2V
There is never any light on microlipo - whether a battery is plugged or not
ulianaapatina
by ulianaapatina on Wed Dec 27, 2017 6:45 am
I think I found what I was doing wrong - I did not plug microlipo in usb port :)
Have a great New Year!
ulianaapatina
by ulianaapatina on Wed Dec 27, 2017 10:00 am
Hi again,
Thank you for your previous replies.
Could you please advice how long it usually takes to charge one battery. It’s plugged in for 2 hours already and the light is still bright red (haven’t changed on green to indicate that a battery unit is charged).
ulianaapatina
by adafruit2 on Wed Dec 27, 2017 2:16 pm
it charges at 100mA so if you battery is 500 mAh it will take 5 (500/100) hours or so
adafruit2
Site Admin
