https://www.adafruit.com/products/259
- Zer0freak
can i use the battery and charge battery at the time using the USB LIION/LIPOLY CHARGER v1.2
Re: https://www.adafruit.com/products/259
Yes. That is possible to do.
- Zer0freak
thanks that helps a ton
- Alejandro11
Hi, Good day. I would like to know why my booster 1000mA is so very hot to touch when we start performing the wireless charging, once we put the receiver with the phone into the transmitter the power boost will now getting hotter to the point you will hurt.
Specs:
Qi receiver
- Receiving voltage : DC 5V / 1A
- Charging voltage: DC 5V / 1A
Power boost 1000C
- Vout: ~5.2V @1A+ output
lipoly battery 3.7V 2000mAh
Trasmitter:
Input Voltage: 5Vdc
Input Voltage(limits): 5Vdc
Output Voltage: 5Vdc
Output Current(maximum): 1.2A
Output Current(no-load): 30~50mA
Transmitter Coil Inductance: 3.7uH
Transmit-receive distance: 2-10mm
Transmitter :22.1*13.1*3.2mm
Coil Diameter: 43mm
Coil Height: 2.3mm
Solar panel
- Pmax: 1.3W
- Vmp: 5.5V
- Imp: 236mA
USB / DC / Solar Lithium Ion/Polymer charger
Thank you for your reply :) Godbless
Specs:
Qi receiver
Power boost 1000C
Trasmitter:
Input Voltage: 5Vdc
Coil Diameter: 43mm
Coil Height: 2.3mm
Solar panel
- Pmax: 1.3W
- Vmp: 5.5V
- Imp: 236mA
- Attachments
- 16935449_120300002303613701_286340699_o.jpg (341.37 KiB) Viewed 3067 times
Please post photos that clearly show all of your connections.
Also, what is the output voltage of the charger board you are using?
