MAX 31856
MAX 31856
by vip_instruments on Mon Apr 03, 2017 7:25 am
Hello There,
I want to have temperature of 3 different sensors. For which I've bought 4 units of MAX 31856 module.
Now, I'm not able to connect more than one module at a time. Please help in connecting all 3 modules to arduino UNO.
vip_instruments
Re: MAX 31856
by adafruit_support_bill on Mon Apr 03, 2017 7:33 am
Wire each as described in the guide, but use a different CS pin for each sensor:
https://learn.adafruit.com/adafruit-max ... spi-wiring
When you declare the 3 sensors in your code, be sure to specify the correct CS pin number for each one:
https://learn.adafruit.com/adafruit-max ... -reference
Re: MAX 31856
by PraveenN on Mon Nov 20, 2017 5:20 am
To Adafruit technical support,
I purchased a MAX31856 for my final year project and it was connected with a cartridge heater(24v,50W) integrated with J-type thermocouple. Temperature was displayed using the given arduino library and when the heater is operated above 5v it displays an error message "Over/Under Voltage Fault".
Here my requirement is to build a temperature controlled heater but in this case it can't be accomplished.
So I would appreciate if you could guide me to avoid this error.
Regards,
Praveen Nuwantha
PraveenN
Re: MAX 31856
by adafruit_support_bill on Mon Nov 20, 2017 7:19 am
The over/under voltage fault occurs when the absolute input voltage at T+ or T- is negative or greater than VDD (3.3v). It is possible that there is some short circuit inside you heater module that is allowing higher voltages to reach the thermocouple probe.
