I bought an IKEA standing/sitting desk that currently uses a hand crank to adjust the height ( http://www.ikea.com/gb/en/products/desk ... -49084965/ ) and I want to attach a powerdrill motor or similar that I can control with the Huzzah feather via Blynk, and then in extension via voice control.
I had a look at the DC motor featherwing addon but it will only do 1.2A and I would have to use a stepper motor which I guestimate, will be quite a bit slower than a power drill motor.
So my idea was to simply control the powerdrill motor via a relay which simply turns it on or off. That wont be as precise but good enough for my use case. Any suggestion on what extra hardware I need besides my Huzzah, or , any other suggestions on how to solve this problem?
Thanks for any advice!
Suggestions for Huzzah controlled sit/standing desk
- markvanhaze
Re: Suggestions for Huzzah controlled sit/standing desk
What kind of drill motor were you thinking of? Due to the lower voltage, cordless drill motors generally require a lot more current than AC drill motors. Most pull at least 20A. If you are using a cordless drill motor, you will need a power source and relay capable of handling that. AC drill motors run at higher voltages, so they need less current to create the same torque.
- markvanhaze
Yes thats what I was thinking. It would be a cordless drill motor, running on something around 12V or higher and I didnt measure it but I expect it to draw well above 1.2A which is the limit for the feather shield. I have a brick that will power the drill, so thats not the problem.
I'm assuming you will need to reverse the motor to lower the desk. To do that you will need an "H-Bridge" capable of switching the high current for your motor. You can buy solid-state H-Bridges, or make one from relays. This Wikipedia article explains how they work: https://en.wikipedia.org/wiki/H_bridge
This instructable shows how to build one: http://www.instructables.com/id/How-to- ... -H-bridge/
