ADS1115 PROBLEMS
Re: ADS1115 PROBLEMS
by Stamos on Wed Jun 21, 2017 4:54 pm
Thats the best answer i could have today from any person !!
If i dont want to use Divider, can i put negative terminal to ADS1115, or doesnt work like that?
Stamos
by Stamos on Wed Jun 21, 2017 4:56 pm
Also can you give me a schematic , my mind is melt now
Stamos
by adafruit_support_bill on Wed Jun 21, 2017 5:32 pm
Something like this:
by Stamos on Wed Jun 21, 2017 5:40 pm
seems brilliant! but a 2:1 wont give me 11.3/2 voltage?? isnt it 5.65 volts in each input???
Also i keep the same grounds on ADS 1115 AS I HAD IT on my schematic and keep what you told me as the only addition???
Stamos
by Stamos on Wed Jun 21, 2017 5:41 pm
sorry i am asking so much but you know each ADS1115 costs 18euros in greece
Stamos
by adafruit_support_bill on Wed Jun 21, 2017 6:17 pm
All the grounds would be to the negative terminal of your 12v supply.
With a voltage of 11.3v across the 2:1 voltage divider as shown, there will be a 7.53v drop across the 2K resistor and a 3.77v drop across the 1K resistor. So the maximum your ADS1115 would see relative to its ground would be 3.77v.
by Stamos on Wed Jun 21, 2017 6:24 pm
Tomorrow i get my new Parts, so i will work on them, unfortunatelly i am in a place away from shops so now i got to order resistors for dividers (i an a student as i told you and i dont have kits e.t.c.)...
Thanks man, you really helped me!1 i sorted somethings out... it took me 3 months to find it out
Stamos
by Stamos on Thu Jun 22, 2017 6:08 am
Kalispera Friend (goodevening)
This is my last scematic, with blue pen circles is the changes, can you confirm?
Stamos
by adafruit_support_bill on Thu Jun 22, 2017 6:23 am
Yes, that looks OK.
by Stamos on Thu Jun 22, 2017 6:31 am
Thank you!!
If i have something new i will inform you
i hope everything works
Stamos
by Stamos on Tue Jun 27, 2017 12:27 pm
Hello Bill
i face a problem of linearity after the voltage divider!!
In low values around 50mV , after the voltage divider i got 10mV
After 1V i got a normal factor 3 times lower values
Before 1V i got a range of 5times lower value ,3.54 , 3.31 , 3.15 do i need to find an equation for this?
Stamos
by adafruit_support_bill on Tue Jun 27, 2017 4:21 pm
It is not clear from your description what exactly you are measuring. Please show us how you are making thee measurements.
by Stamos on Tue Jun 27, 2017 4:35 pm
the schematic is like this we had.
Also, i will get the prices i want from the emmiter also, can i measure there without any divider?
Stamos
by adafruit_support_bill on Tue Jun 27, 2017 4:43 pm
Yes, I am familiar with the circuit. But you didn't answer my question. What exactly are you measuring in that circuit?
50mV between what two points in the circuit? What did you use to measure that?
3.54 what? Volts? Millivolts? What are you measuring and how are you measuring it? Please me specific.
by Stamos on Tue Jun 27, 2017 4:50 pm
i used Multimeter before i use my ADS!!
3.54 i mean times Lower price (the prices i told you are factors). mean i didnt get (30mV bofore voltage divider and after 10mV) or (60mV-20mV)
i dont like Voltage divider there, can i go with the circuit i will attach?? i got the same prices i need but with lower voltages instead..
Sorry for being tyring
Stamos
