๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday October 14, 2019 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday October 11 will go out Tuesday October 15 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Increase GPSD capture speed?
by jamiedixon on Tue Jul 11, 2017 12:31 pm
I am following the article found here: https://learn.adafruit.com/adafruit-ult ... g-your-gps
I am capturing the data at 1 second - the default
How can I capture at the fastest speed (which, I understand to be 10 MZ or 1/10 of a second)?
the GPSD api docs do not say AFAIK
jamiedixon
Re: Increase GPSD capture speed?
by adafruit_support_rick on Wed Jul 12, 2017 8:24 am
Don't know much about gpsd, but you can cat this command to the GPS to set it for 10Hz:
$PMTK300,100,0,0,0,0*2C
It needs a <cr><lf> at the end to be processed
by jamiedixon on Wed Jul 12, 2017 9:00 am
Yeah - I am searching their list serve (http://lists.nongnu.org/archive/cgi-bin ... sort=score) and someone else had the same issue
Looks like I can't tell the board to speed up the output via their api, so I either have to set it via the command line or figure out how to pass $PMTK300,100,0,0,0,0*2C somewhere in their api
I might make a pull request of an interface of setOutputSpeed(int) and have the 1 implementation that $PMTK300,100,0,0,0,0*2C can pass to the board.
jamiedixon
by adafruit_support_rick on Wed Jul 12, 2017 3:22 pm
Just use echo from the command line. As long as the backup battery is installed in the GPS, the setting will persist.
echo '$PMTK300,100,0,0,0,0*2C\r\n' > /dev/tty_AMA0
by jamiedixon on Wed Jul 12, 2017 3:25 pm
jamiedixon
