Current rating for Adafruit 16-Channel 12-bit PWM/Servo Driv
by saurabhsaurc on Thu Jul 27, 2017 11:00 am
I would like to know what would be the maximum current rating for this board Adafruit 16-Channel 12-bit PWM/Servo Driver - I2C interface - PCA9685
https://www.adafruit.com/product/815
I want to drive some high power LEDs (say 20W) and vary the voltage via PWM. I suppose the pwm output from this board would need to be amplified by a H-bridge chip such as L298d in order to meet the higher current rating. Am I correct?
saurabhsaurc
Re: Current rating for Adafruit 16-Channel 12-bit PWM/Servo
by adafruit_support_carter on Sun Jul 30, 2017 6:28 pm
The power output pin is tied directly to the power input on the screw terminal block. See schematic:
https://learn.adafruit.com/assets/36269
so can pass through a fair amount of current. Do you know what your max current will be for your setup?
by saurabhsaurc on Sun Jul 30, 2017 11:25 pm
Never mind.. I realized that I would be needing an LED driver circuit to connect with the PWM output. Thanks anyway.
saurabhsaurc
