3W-9W RGB LED hookup question
by chrisbienert on Thu Aug 10, 2017 4:18 pm
3W-9W RGB LED - Common Anode
PRODUCT ID: 2524
I am trying to figure out if i can use this directly with a constant voltage led controller. I couldn't find anything in the data sheet.
Chris
chrisbienert
Re: 3W-9W RGB LED hookup question
by franklin97355 on Thu Aug 10, 2017 5:51 pm
What are the specs for the controller?
franklin97355
by chrisbienert on Thu Aug 10, 2017 7:26 pm
Its a constant voltage driver that receives DMX 512 signal and converts to pwm signal. Input voltage can be between 12 - 36 volts and supply up to 5 amps per channel.
Hope that clarifies things a bit
chrisbienert
by adafruit_support_mike on Fri Aug 11, 2017 12:52 am
You'll need to control either the voltage or the current.
The red LED's forward voltage is 2.5v @ 350mA. The green and blue LEDs have the same forward voltage of 3.6v @ 350mA.
The 12v-36v @ 5A channels you described would kill the LEDs as soon as the current started flowing.
by adafruit2 on Fri Aug 11, 2017 1:08 pm
ya you definitely will need a step-down converter for each LED that is constant current. we don't stock any but check out
https://www.sparkfun.com/products/13705 - it may work !
adafruit2
Site Admin
by chrisbienert on Fri Aug 11, 2017 2:43 pm
Perfect I ordered the 9 watt rgb led and the constant current driver yesterday thinking "well just in case" so I am glad that I did now. Thanks for your help!
chrisbienert
