WiPy 2.0 LCD
WiPy 2.0 LCD
by ripplingwater75 on Fri Sep 15, 2017 7:11 am
hi,
If I intend to use a LCD ( to display some information like the IP address, SSID of the WLAN or the number of nodes connected to a pycom device ( WiPy 2.0 ) which of the LCDs would be easy and nice to use? Thanks a ton!
Cheers,
R.W
ripplingwater75
Re: WiPy 2.0 LCD
by franklin97355 on Fri Sep 15, 2017 12:38 pm
How big do you want it to be and what resolution. How much data will you want to display at one time and how long will the lines be (characters)
franklin97355
Re: WiPy 2.0 LCD
by ripplingwater75 on Sat Sep 16, 2017 12:52 am
Prefer it not to be too big as I intend to fix these on the sensor nodes. Typically 80-100 characters ( text ) should suffice. As for the resolution, not too particular about that because the information I'd be displaying is stuff like the IP Address, Temperature and humidity readings. Thanks
Cheers,
R.W
ripplingwater75
Re: WiPy 2.0 LCD
by franklin97355 on Sat Sep 16, 2017 1:39 am
This would work for 80 characters. https://www.adafruit.com/product/198
franklin97355
Re: WiPy 2.0 LCD
by ripplingwater75 on Sat Sep 16, 2017 2:01 am
franklin97355 wrote:This would work for 80 characters. https://www.adafruit.com/product/198
Alrighty, looks cool, thanks. Btw could any of the other display ( with changing back colors ) work too? This is so that I can change the color ( say to red / amber ) to indicate that something is not right, or as a warning light?
Cheers,
R.W
ripplingwater75
Re: WiPy 2.0 LCD
by franklin97355 on Sat Sep 16, 2017 3:19 am
Sure.
franklin97355
Re: WiPy 2.0 LCD
by ripplingwater75 on Sat Sep 16, 2017 10:14 pm
franklin97355 wrote:Sure.
Then just a quick question - would the "negative LCD" or "positive LCD" be easier to use with the WiPy 2.0 ( or LoPy )? Thanks a ton
ripplingwater75
