Lines on the screen : 5.0" 40-pin 800x480 TFT Display withou
by djblex on Sun Sep 24, 2017 5:07 pm
Following my first request “Adafruit 5 "TFT HDMI image remains superimposed in background “
Still with the super game pi project. (https://learn.adafruit.com/super-game-pi/overview)
I have another problem and hope that you will be able to help me.
It Appears 2 lines on the left (purple) and on the top (green ).
The same, i tried many settings : overscan, led framerate.. but no changement.
is there a way to remove these lines ?
Than you
djblex
Re: Lines on the screen : 5.0" 40-pin 800x480 TFT Display wi
by adafruit2 on Mon Sep 25, 2017 11:49 am
hiya looks like you are 'forcing' audio thru HDMI - that's the audio data! try forcing audio to headphone
adafruit2
Site Admin
by djblex on Mon Sep 25, 2017 12:26 pm
djblex
Hello, thank you for your answer.
My boot config.txt has these lines as mentionned on the adafruit tutorial (https://learn.adafruit.com/super-game-pi/software)
However the sound works great on jack headphone.
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 800 480 60 6 0 0 0
arm_freq=900
core_freq=250
sdram_freq=450
over_voltage=2
avoid_safe_mode=1
gpu_mem=256
overscan=1
djblex
by djblex on Mon Sep 25, 2017 12:28 pm
is there a command line to force the headphone output ?
djblex
by adafruit2 on Mon Sep 25, 2017 12:38 pm
sudo raspi-config
adafruit2
Site Admin
by djblex on Mon Sep 25, 2017 12:41 pm
i have done it from the beginning of the project :)
So it could be another problem ?
djblex
by adafruit2 on Mon Sep 25, 2017 12:49 pm
hmm - what happens if you plug it into a 'normal' computer like windows or mac?
adafruit2
Site Admin
by djblex on Mon Sep 25, 2017 1:13 pm
I tried once but the screen was black, no signal, so i didn't insist.
I am going to try again but i think i need to configure Windows in screen size 800*480 to have a signal.
I come back when the test will be done.
Thank you.
djblex
by adafruit2 on Mon Sep 25, 2017 1:25 pm
thanks, that will help us figure it out *a lot*!
adafruit2
Site Admin
by djblex on Mon Sep 25, 2017 5:52 pm
So, i plugged the screen on Windows 10 but black screen : still no signal. i don't have te exactly 800X480 resolution . i tried all settings but it doesn't work.
Any idea for the colors lines ?
I have two identical screens. The lines appear on both with my RPIs..
djblex
by adafruit2 on Mon Sep 25, 2017 6:21 pm
hmm if both do the same thing its probably not a hardware thing. ok can you try installing raspbian on the pi? see if that looks good?
adafruit2
Site Admin
by djblex on Mon Sep 25, 2017 7:02 pm
yes sure, i 'll do it tomorrow; good idea.
Thank you
djblex
by djblex on Mon Sep 25, 2017 7:08 pm
but you don't think it can be a default production. Because they have the same date reference in back . And they do the same problem of superimposed images in background.
It was suggestion :)
Because have you seen this another problem yet?
thank you
djblex
by adafruit2 on Mon Sep 25, 2017 7:12 pm
this is the first time it wasnt solved by hdmi audio stuff - its really unlikely its hardware, just because we only use one chip and there's no firmware, it 'just works' :)
adafruit2
Site Admin
