10 DOF IMU - L3GD20 Library is not working
by fatihdag on Thu Sep 28, 2017 8:24 am
Dears,
I have 10 DOF IMU with L3GD20 gyroscope. I can't read sensor output with Adafruit_L3GD20_U library ( https://github.com/adafruit/Adafruit_L3GD20_U).
Code stucks in the following part:
   if(!gyro.begin())
    /* There was a problem detecting the L3GD20 ... check your connections */
    Serial.print("Ooops, no L3GD20 detected ... Check your wiring or I2C ADDR!");
    while(1);
When I remove this part, output becomes as below:
Gyroscope Test
Sensor: L3GD20
Driver Ver: 1
Unique ID: 20
Max Value: 0.00 rad/s
Min Value: 0.00 rad/s
Resolution: 0.00 rad/s
X: -0.02 Y: -0.02 Z: -0.02 rad/s
Please note that it is working with other codes that i found in the internet.
Waiting your support.
fatihdag
Re: 10 DOF IMU - L3GD20 Library is not working
by jps2000 on Thu Sep 28, 2017 2:59 pm
check if sda and scl are properly wired and that there are pullups (4k7) on each line
jps2000
cron
