Can't get 8x8 minimatrix to work anymore
by joosteerbeek on Mon Dec 04, 2017 6:07 am
I recently got the Adafruit 8x8 red 0,8"matrix. I'm using it with the Arduino Nano. Last week I got it to work with the example code. But this week the matrix won't do anything, with that same code. I added some println's to test where it goes wrong. And it seems to stop working after the code says
matrix.begin(0x70);
You can see that in the serial monitor test1 does print, but test2 doesn't... If I comment out matrix.begin(0x70); then test3 prints as well. just one time.
#include <Adafruit_LEDBackpack.h>
#include <gfxfont.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SPITFT.h>
#include <Adafruit_SPITFT_Macros.h>
#include <Wire.h>
  This is a library for our I2C LED Backpacks
  Designed specifically to work with the Adafruit LED Matrix backpacks
  ----> http://www.adafruit.com/products/872
  ----> http://www.adafruit.com/products/871
  ----> http://www.adafruit.com/products/870
  These displays use I2C to communicate, 2 pins are required to
  interface. There are multiple selectable I2C addresses. For backpacks
  with 2 Address Select pins: 0x70, 0x71, 0x72 or 0x73. For backpacks
  with 3 Address Select pins: 0x70 thru 0x77
  products from Adafruit!
Adafruit_8x8matrix matrix = Adafruit_8x8matrix();
  Serial.begin(9600);
  Serial.println("8x8 LED Matrix Test");
  Serial.println("test1");
  matrix.begin(0x70);  // pass in the address
  Serial.println("test2");
static const uint8_t PROGMEM
  smile_bmp[] =
  { B00111100,
    B01000010,
    B10100101,
    B10000001,
    B10100101,
    B10011001,
    B01000010,
    B00111100 },
  neutral_bmp[] =
  { B00111100,
    B01000010,
    B10100101,
    B10000001,
    B10111101,
    B10000001,
    B01000010,
    B00111100 },
  frown_bmp[] =
  { B00111100,
    B01000010,
    B10100101,
    B10000001,
    B10011001,
    B10100101,
    B01000010,
    B00111100 };
  Serial.println("test3");
  matrix.clear();
  matrix.drawBitmap(0, 0, smile_bmp, 8, 8, LED_ON);
  matrix.writeDisplay();
  delay(500);
  matrix.clear();
  matrix.drawBitmap(0, 0, neutral_bmp, 8, 8, LED_ON);
  delay(500);
  matrix.clear();
  matrix.drawBitmap(0, 0, frown_bmp, 8, 8, LED_ON);
  delay(500);
  matrix.clear();      // clear display
  matrix.drawPixel(0, 0, LED_ON);
  matrix.writeDisplay();  // write the changes we just made to the display
  delay(500);
  matrix.clear();
  matrix.drawLine(0,0, 7,7, LED_ON);
  delay(500);
  matrix.clear();
  matrix.drawRect(0,0, 8,8, LED_ON);
  matrix.fillRect(2,2, 4,4, LED_ON);
  delay(500);
  matrix.clear();
  matrix.drawCircle(3,3, 3, LED_ON);
  delay(500);
  matrix.setTextSize(1);
  matrix.setTextWrap(false);  // we dont want text to wrap so it scrolls nicely
  matrix.setTextColor(LED_ON);
  for (int8_t x=0; x>=-36; x--) {
    matrix.clear();
    matrix.setCursor(x,0);
    matrix.print("Hello");
    delay(100);
  matrix.setRotation(3);
  for (int8_t x=7; x>=-36; x--) {
    matrix.clear();
    matrix.print("World");
    delay(100);
  matrix.setRotation(0);
The wires are connected as followed:
See the image..
I hope you can help me with this!
joosteerbeek
Re: Can't get 8x8 minimatrix to work anymore
by franklin97355 on Tue Dec 05, 2017 4:13 am
Can you post a picture of the other side? Your soldering could use a reflow to completely wet the pin and pad for good connections.
franklin97355
by joosteerbeek on Tue Dec 05, 2017 4:26 am
franklin97355 wrote:Can you post a picture of the other side? Your soldering could use a reflow to completely wet the pin and pad for good connections.
Okay. I will do that on thursday.
joosteerbeek
by joosteerbeek on Thu Dec 07, 2017 6:09 am
Hereby the picture
joosteerbeek
by franklin97355 on Thu Dec 07, 2017 4:11 pm
Check out this Soldering Guide and redo your connections and see if that helps.
franklin97355
by joosteerbeek on Thu Dec 07, 2017 6:19 pm
franklin97355 wrote:Check out this Soldering Guide and redo your connections and see if that helps.
Thanks! Will try on monday. I'll let you know if that works.
joosteerbeek
by bestazy on Thu Dec 21, 2017 8:04 am
Hi ! thanks for good tutorial, but I couldn't found question on my answer there
I was just wondering if u could put up a detailed picture on how to hook up another 8×8 led matrix and the code so it will work and can I use just 3 shift registers to do this ?
Thanks very much, bestazy
bestazy
