Rasp Pi 1M Flex Cable Not Usable
by wiz69 on Mon Jan 01, 2018 8:55 pm
Order # 1633389. I have used my Rasp Pi 2 with a Pi Camera V2, for quite a while with the Flex Cable provided with the Pi Camera. My current application requires to locate the Camera at least 24" - 30" away from the Rasp Pi 2.
After installing the 1 meter cable to interconnect the Camera and Rasp Pi 2, I had intermittent video. When I was able to position the Flex Cable to have solid video, I installed the clear plastic cover provided in my order of the Camera Case with 1/4" Tripod Mount. The video went dead. I removed the clear plastic cover and video came back. I repeated this operation 4 times with the same results. Yes, I did install the clear plastic cover properly.
FYI, I am a EE with many years experience in circuit design and applications. I researched the Internet usage of the 1 meter cable and found numerous issues with its use. I have no problem returning the 1 meter cable and would need a 24" Flex cable sent to me.
I am leaving town in 11 days and need a replacement immediately. I can't have a unreliable setup.
Please advise ASAP.... Thanks
wiz69
Re: Rasp Pi 1M Flex Cable Not Usable
by franklin97355 on Mon Jan 01, 2018 10:48 pm
Have you tried the original cable after having the problem?
franklin97355
by wiz69 on Tue Jan 02, 2018 12:14 am
Yes... Works fine...
wiz69
by franklin97355 on Tue Jan 02, 2018 1:08 am
If you placed the order within the last 30 days please contact support@adafruit.com with a link to this topic and your order number and they will help you get a replacement cable
franklin97355
