RFID controller breakout board + Raspberry PI
by JefKeijers on Sun Jun 09, 2013 11:18 am
I'm working on a little RFID project but I've a question about it.
How can I connect the raspberry PI with the (PN532 NFC/RFID controller breakout board)?
Is this possible via the (USB FTDI TTL-232 cable - TTL-232R 3.3V) or do I need the PI cobbler with a breadboard?
(I'm totally not good in soldering things up so the USB cable would be very pleasant :lol: )
Jef Keijers
JefKeijers
Re: RFID controller breakout board + Raspberry PI
by adafruit_support_rick on Sun Jun 09, 2013 1:09 pm
The cobbler is convenient, but not absolutely necessary. You can insert the jumper wires directly into the GPIO socket on the Pi. The Cobbler really is nothing more than a 40-pin jumper cable. The pin mapping on the Cobbler is identical to the pin mapping in the GPIO socket.
I assume you've been looking at our tutorial?
I suppose it's possible to use an FTDI USB serial cable. You would need to install the appropriate FTDI driver. Otherwise, I have no experience with connecting to the RFID breakout this way.
by JefKeijers on Mon Jun 10, 2013 8:23 am
Oké, I'll try it with the FTDI cable and let you guys know if it worked out well ;)
But one more question:
If I use the FTDI cable which protocol I have to use? i2c,SPI or UART?
JefKeijers
by adafruit_support_rick on Mon Jun 10, 2013 9:57 am
You would use UART, and you would communicate through libnfc
