Anyone who still has these communication problems, there are few things to know:
-The configuration tool requires .NET framework 2.0 and if you install higher version it will not work (although it should, thanks Microchip for the great software). Note that Windows 7 comes with .NET framework 2.0 built into the system, you don't need to install it if you run this operating system.
-If you installed the UPDD driver from the Microchip's page - remove it, there should be no specific driver installed, just the default ones from the operating system.
Can't communicate with AR1100
