PPS signal measure, GPS GTPA013
by Gambox on Mon Mar 31, 2014 2:44 pm
Hi, I have some problem with the PPS signal of the GTPA013. I power on the device and I put in the PPS output Oscilloscope tip but I can see nothing. I expected to see a square wave o pulse witdh with 50ms of duration.
http://www.adafruit.com/products/746#Downloads
Gambox
Re: PPS signal measure, GPS GTPA013
by adafruit_support_rick on Wed Apr 02, 2014 4:30 pm
I believe the PPS must be enabled in software. It's not on by default.
by geogeo on Wed Apr 30, 2014 9:43 am
Could you confirm that v3 Breakout with GTPA013 needs specific software command to enable PPS output!???
geogeo
by adafruit_support_rick on Thu May 01, 2014 6:46 am
Upon further review, the decision in my previous post is reversed. Sorry about that...
The 1PPS is normally on. No command to enable it is required. In fact, there is no PPS-related command at all. You can't turn it off, either.
by geogeo on Thu May 01, 2014 6:55 am
Ok, no problem, thank you for clearing!
geogeo
