Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more. Accepting essential orders - here's how.
Wired power and battery power
by dcastator on Mon May 26, 2014 4:58 pm
I built a wireless BT foot pedal using the EZ key BT HID keyboard. I want to modify the unit to utilize a lithium battery pack. I also want to utilize a 5V switching power supply when I need to charge the lithium battery. While charging the battery I also want to be able to use the unit and power it by the 5v switching power supply. In doing so would I be sending more than 5v to the EZ-Key board? (5V from the switching power supply & what every power is in the lithium battery)? Or does the battery disconnect while charging? I just want the option to use the pedal on battery power or while plugged in.
Any assistance you can give your be greatly appreciated.
Regards,
dcastator
Re: Wired power and battery power
by adafruit_support_bill on Tue May 27, 2014 6:00 am
You could use any of our LiPo chargers. These two allow you to connect the load in parallel with the battery, so the EZ-Key will see the same voltage as the battery at all times.
https://www.adafruit.com/products/280
https://www.adafruit.com/products/259
This charger has a load-sharing circuit that diverts power directly to the load when a power supply is connected. With a 5v supply, the EZ-Key would see 5v when the battery was charging.
https://www.adafruit.com/products/390
Any of the above would work with the EZ-Key
by dcastator on Tue May 27, 2014 7:52 am
Perfect! I looked at these boards but wanted to make sure I was going to get what I was attempting to achieve..
Just ordered 2....
Thank you!
Regards
dcastator
