So, I have a 16x32 LED Panel and I have configured it with an Arduino UNO and using Processing i have been able to make it a spectrum Analyzer.
What i really want to do is hook up an electret microphone so it does not need to be hooked up to Processing/my computer the entire time.
Having trouble finding help on this online.
I want to do something very similar to the Piccolo project on here, but with a 16x32 LED panel instead of the the 8x8.
Help??
16x32 LED Panel as Spectrum Analyzer (need help!)
- kctheelephant
- adafruit_support_rick
Re: 16x32 LED Panel as Spectrum Analyzer (need help!)
Are you looking to do something like this?
https://learn.adafruit.com/piccolo/overview
- pburgess
This might work. Requires the ffft library (same as used by Piccolo). In ffft.h, FFT_N *must* be set to 64 for this to work. Also, you might need to tweak the CLK/LAT/OE pin assignments to match your matrix wiring.
#include <avr/pgmspace.h>
#include <ffft.h>
#include <math.h>
#include <Adafruit_GFX.h> // Core graphics library
#include <RGBmatrixPanel.h> // Hardware-specific library
#define CLK 8 // MUST be on PORTB!
#define LAT 9
#define OE 9
#define A A0
#define B A1
#define C A2
RGBmatrixPanel matrix(A, B, C, CLK, LAT, OE, false);
#define ADC_CHANNEL 3 // Analog pin
int16_t capture[FFT_N]; // Audio capture buffer
complex_t bfly_buff[FFT_N]; // FFT "butterfly" buffer
uint16_t spectrum[FFT_N/2]; // Spectrum output buffer
volatile byte samplePos = 0; // Buffer position counter
// In library file ffft.h, FFT_N *must* be set to 64. Due to the RGB
// matrix overhead, there's only enough RAM for a 64 sample FFT buffer
// (32 spectrum outputs). Any higher WILL fail!
byte
peak[32], // Peak level of each column; used for falling dots
count = 0; // Frame counter for delaying dot-falling speed
int
minLvlAvg = 0, // For dynamic adjustment of low & high ends of the graph,
maxLvlAvg = 512; // pseudo rolling averages for the prior few frames.
// These two tables help the graph adjust dynamically to varying input:
PROGMEM uint8_t
// This is low-level noise that's subtracted from each FFT output column:
lower[32] = { 44,28,5,6,4,3,3,5,3,4,5,4,4,4,4,5,
3,4,4,3,4,4,4,4,4,3,4,3,4,3,4,5 },
// These are scaling quotients for each column. Partly for filtering out
// low-frequency (~150 Hz) noise from the FFT, and also because most music
// is simply heavy toward the low end (rhythm, bass).
upper[32] = { 200,160,90,48,23,11,5,3,1,1,0,0,0,0,0,0,
0, 0, 0, 0, 0, 0,0,0,0,0,0,0,0,0,0,0 };
memset(peak, 0, sizeof(peak));
matrix.begin();
// Init ADC free-run mode; f = ( 16MHz/prescaler ) / 13 cycles/conversion
ADMUX = ADC_CHANNEL; // Channel sel, right-adj, use AREF pin
ADCSRA = _BV(ADEN) | // ADC enable
_BV(ADSC) | // ADC start
_BV(ADATE) | // Auto trigger
_BV(ADIE) | // Interrupt enable
_BV(ADPS2) | _BV(ADPS1) | _BV(ADPS0); // 128:1 / 13 = 9615 Hz
ADCSRB = 0; // Free run mode, no high MUX bit
DIDR0 = 1 << ADC_CHANNEL; // Turn off digital input for ADC pin
TIMSK0 = 0; // Timer0 off
sei(); // Enable interrupts
char c;
byte x, y, y2, r, g, b;
int hue, minLvl, maxLvl;
uint16_t n;
long level;
while(ADCSRA & _BV(ADIE)); // Wait for audio sampling to finish
fft_input(capture, bfly_buff); // Samples -> complex #s
samplePos = 0; // Reset sample counter
ADCSRA |= _BV(ADIE); // Resume sampling interrupt
fft_execute(bfly_buff); // Process complex data
fft_output(bfly_buff, spectrum); // Complex -> spectrum
// Get min & max levels in FFT output:
for(x=0; x<32; x++) {
level = (long)spectrum[x] - (long)pgm_read_byte(&lower[x]); // rm noise
if(level < 0L) level = 0L; // Clip...else fixed-point scale:
else level = (level * (256L - pgm_read_byte(&upper[x]))) >> 8;
if(x == 0) {
minLvl = maxLvl = level;
} else {
if(level < minLvl) minLvl = level;
else if(level > maxLvl) maxLvl = level;
// minLvl and maxLvl indicate the extents of the FFT output, used
// for vertically scaling the output graph (so it looks interesting
// regardless of volume level). If they're too close together though
// (e.g. at very low volume levels) the graph becomes super coarse
// and 'jumpy'...so keep some minimum distance between them (this
// also lets the graph go to zero when no sound is playing):
if((maxLvl - minLvl) < 8) maxLvl = minLvl + 8;
minLvlAvg = (minLvlAvg * 7 + minLvl) >> 3; // Dampen min/max levels
maxLvlAvg = (maxLvlAvg * 7 + maxLvl) >> 3; // (fake rolling average)
// Render display:
for(x=0, hue=0; x<32; x++, hue += 40) { // For each column...
// Second fixed-point scale based on dynamic min/max levels:
level = ((level - minLvlAvg) * 16L) / (long)(maxLvlAvg - minLvlAvg);
// Clip output and convert to byte (column height...0 to 16):
if(level < 0L) c = 0;
else if(level > 16L) c = 16;
else c = (char)level;
if(c > peak[x]) peak[x] = c; // Keep white dot on top
if(peak[x] <= 0) { // Empty column?
matrix.drawLine(x, 0, x, 15, 0);
continue;
y = 16 - peak[x]; // y = 0 to 15
if(y > 0) matrix.drawLine(x, 0, x, y-1, 0); // Fill black above peak
// WILL CRASH HERE if out of RAM!
matrix.drawPixel(x, y, 0xffff); // Draw white dot at peak
// Draw fading streak from below peak to just above current level
for(y++, y2 = 16 - c, n=150; y < y2; y++) {
matrix.drawPixel(x, y, matrix.ColorHSV(hue, 255, n, true));
if(n >= 50) n -= 50;
// Draw bar for current level, with slight glow at top
y = y2;
n = 100;
// If current level is peak, don't overwrite white dot
if(c == peak[x]) {
y++;
n = 150;
while(y < 16) {
matrix.drawPixel(x, y, matrix.ColorHSV(hue, n, 255, true));
n += 50;
if(n > 255) n = 255;
y++;
// Every alternate frame, make the peak pixels drop by 1:
if(++count == 1) {
count = 0;
if(peak[x] > 0) peak[x]--;
ISR(ADC_vect) { // Audio-sampling interrupt
static const int16_t noiseThreshold = 4;
int16_t sample = ADC; // 0-1023
capture[samplePos] =
((sample > (512-noiseThreshold)) &&
(sample < (512+noiseThreshold))) ? 0 :
sample - 512; // Sign-convert for FFT; -512 to +511
if(++samplePos >= FFT_N) ADCSRA &= ~_BV(ADIE); // Buffer full, interrupt off
- kctheelephant
The code you gave me seems like it will work when i understand it better! i'm a little lost on all the #defines though. for my 16x32 panel i have plugged it into my Arduino just like the Adafruit wiring guide says.
Could you explain your code a little more? Or guide me to more tutorials on this type of code?
Thank you!
Thank you!
- pburgess
Hmmm...actually I'd suggest changing one wire vs. the standard tutorials: move the LAT wire from pin A3 to pin 9 (you'll probably need to use a breadboard or solder up a little Y-splitter jumper, since this pin is now going both to LAT and OE). 3.3V goes to mic amp + and the Arduino's AREF pin. Mic output goes to A3. Mic - to GND. Then use the code as-is.
As for explaining it...erf...this is actually some pretty hairy stuff and would fill a book. If there's anything specific that's not covered in the comments, I could try to offer some guidance, but otherwise it's extremely non-trivial. I just had it around from a project we never released, posted it since it pretty much matches your description.
- kctheelephant
I tried what you suggested in the previous comment and used your code as is, i got no results. Then i tried moving the LAT to a3, the mic to A4, and the OE at pin 9, and editted the code accordingly, still with no results.
Any ideas?
Any ideas?
- pburgess
Use the wiring layout suggested; this was chosen for a reason, though it's been so long I can't remember exactly what that reason was. But I digress...
Did you change the ffft.h library as described?
If it still refuses to work, I would suggest first trying to get some of the other RGBmatrix library examples working with the alternate wiring as described (LAT on pin 9, should require just a one-line change to most of the demos). If it doesn't work, then either A) the wiring is wrong, or B) the code doesn't match the wiring. I can't help troubleshoot this further without A) clear photos of the wiring between Arduino and matrix, and B) the pin #defines and RGBmatrix constructor call from the beginning of the sketch.
Once you get that working, then try the full code I previously posted here.
- kctheelephant
Where/what exactly in the fft needs to be changed? I'm struggling to find it.
- pburgess
Second line in ffft.h:
Should be changed to:
#define FFT_N 128 /* Number of samples (64,128,256,512). */
#define FFT_N 64 /* Number of samples (64,128,256,512). */
- rb3
Is the the correct modification do get around the update to Ardunio 1.6.6?
PROGMEM const uint8_t
Yes, that will work
- gbalici
Hello, what to use if instead of a mic I want to use a line in?
Could that be connected to A4?
Why LAT and OE are connected to pin 9? Shouldn't LAT be connected to A3?
What is the voltage of the line-in signal? it should be biased so that the range is 0 to 5V (0 to 3.3V if you're using a 3.3V processor.
As Phil said in his earlier post:gbalici wrote:Why LAT and OE are connected to pin 9? Shouldn't LAT be connected to A3?
- gbalici
I was hoping you'd remember it :)
