connectors
connectors
by lnkjacobh on Tue Sep 09, 2014 3:35 pm
hello,
Im looking for something to make a connection between a switch and pcb board. I like the 2 pin JST cable, product id: 261, and the mating product JST-PH-2-PIN right angle connector, product id: 1769, however I would prefer the the contacts for both the connector and the cable be gold coated. The reason being is so no oxidation can occur. Is there anything like that? Also is there a connector that is a mating product to the JST cable that is a through hole connector? any help would be greatly appreciated! thanks in advance!
lnkjacobh
Re: connectors
by adafruit_support_rick on Tue Sep 09, 2014 5:52 pm
You probably want to have a look at connectors at Digikey, Mouser, or Jameco. Mouser and Digikey will have thousands of options for this type of connector, and a nice web search feature that will narrow it down quickly.
Re: connectors
by Vishnujah on Thu May 19, 2016 5:27 pm
I am using the JST SM connector, and on the datasheet it says it comes in phosphor bronze, tin plated, however I would like to purchase the one that is gold. Does this model come in gold? I have attached the datasheet for reference.
http://www.jst-mfg.com/product/pdf/eng/eSM.pdf
Thanks for the help!
Vishnujah
Re: connectors
by franklin97355 on Thu May 19, 2016 10:18 pm
According to that datasheet it does not. See page 2 Materials and Finish.
franklin97355
