10 DOF IMU not functioning
by chunkit on Wed Nov 25, 2015 3:59 am
Hi, my 10 DOF adafuit IMU sensor is not working well, there is no output data from the IMU. The data will hang in the middle while displaying through Arduino serial monitor. Sometime, the data will not even displayed in the serial monitor. Please refer to the print screen results showing that the data was stopped in the halfway and data failed to display in serial monitor. Is this caused by IMU itself?
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_LSM303_U.h>
#include <Adafruit_BMP085_U.h>
#include <Adafruit_L3GD20_U.h>
#include <Adafruit_10DOF.h>
/* Assign a unique ID to the sensors */
Adafruit_LSM303_Accel_Unified accel = Adafruit_LSM303_Accel_Unified(30301);
Adafruit_LSM303_Mag_Unified   mag   = Adafruit_LSM303_Mag_Unified(30302);
Adafruit_BMP085_Unified       bmp   = Adafruit_BMP085_Unified(18001);
Adafruit_L3GD20_Unified       gyro  = Adafruit_L3GD20_Unified(20);
void displaySensorDetails(void)
  sensor_t sensor;
  accel.getSensor(&sensor);
  Serial.println(F("----------- ACCELEROMETER ----------"));
  Serial.print  (F("Sensor:       ")); Serial.println(sensor.name);
  Serial.print  (F("Driver Ver:   ")); Serial.println(sensor.version);
  Serial.print  (F("Unique ID:    ")); Serial.println(sensor.sensor_id);
  Serial.print  (F("Max Value:    ")); Serial.print(sensor.max_value); Serial.println(F(" m/s^2"));
  Serial.print  (F("Min Value:    ")); Serial.print(sensor.min_value); Serial.println(F(" m/s^2"));
  Serial.print  (F("Resolution:   ")); Serial.print(sensor.resolution); Serial.println(F(" m/s^2"));
  Serial.println(F("------------------------------------"));
  Serial.println(F(""));
  gyro.getSensor(&sensor);
  Serial.println(F("------------- GYROSCOPE -----------"));
  Serial.print  (F("Max Value:    ")); Serial.print(sensor.max_value); Serial.println(F(" rad/s"));
  Serial.print  (F("Min Value:    ")); Serial.print(sensor.min_value); Serial.println(F(" rad/s"));
  Serial.print  (F("Resolution:   ")); Serial.print(sensor.resolution); Serial.println(F(" rad/s"));
  mag.getSensor(&sensor);
  Serial.println(F("----------- MAGNETOMETER -----------"));
  Serial.print  (F("Max Value:    ")); Serial.print(sensor.max_value); Serial.println(F(" uT"));
  Serial.print  (F("Min Value:    ")); Serial.print(sensor.min_value); Serial.println(F(" uT"));
  Serial.print  (F("Resolution:   ")); Serial.print(sensor.resolution); Serial.println(F(" uT"));
  bmp.getSensor(&sensor);
  Serial.println(F("-------- PRESSURE/ALTITUDE ---------"));
  Serial.print  (F("Max Value:    ")); Serial.print(sensor.max_value); Serial.println(F(" hPa"));
  Serial.print  (F("Min Value:    ")); Serial.print(sensor.min_value); Serial.println(F(" hPa"));
  Serial.print  (F("Resolution:   ")); Serial.print(sensor.resolution); Serial.println(F(" hPa"));
  delay(500);
void setup(void)
  Serial.begin(115200);
  Serial.println(F("Adafruit 10DOF Tester")); Serial.println("");
  /* Initialise the sensors */
  if(!accel.begin())
    /* There was a problem detecting the ADXL345 ... check your connections */
    Serial.println(F("Ooops, no LSM303 detected ... Check your wiring!"));
    while(1);
  if(!mag.begin())
    /* There was a problem detecting the LSM303 ... check your connections */
    Serial.println("Ooops, no LSM303 detected ... Check your wiring!");
    while(1);
  if(!bmp.begin())
    /* There was a problem detecting the BMP085 ... check your connections */
    Serial.print("Ooops, no BMP085 detected ... Check your wiring or I2C ADDR!");
    while(1);
  if(!gyro.begin())
    /* There was a problem detecting the L3GD20 ... check your connections */
    Serial.print("Ooops, no L3GD20 detected ... Check your wiring or I2C ADDR!");
    while(1);
  /* Display some basic information on this sensor */
  displaySensorDetails();
void loop(void)
  /* Get a new sensor event */
  sensors_event_t event;
  /* Display the results (acceleration is measured in m/s^2) */
  accel.getEvent(&event);
  Serial.print(F("ACCEL "));
  Serial.print("X: "); Serial.print(event.acceleration.x); Serial.print("  ");
  Serial.print("Y: "); Serial.print(event.acceleration.y); Serial.print("  ");
  Serial.print("Z: "); Serial.print(event.acceleration.z); Serial.print("  ");Serial.println("m/s^2 ");
  /* Display the results (magnetic vector values are in micro-Tesla (uT)) */
  mag.getEvent(&event);
  Serial.print(F("MAG   "));
  Serial.print("X: "); Serial.print(event.magnetic.x); Serial.print("  ");
  Serial.print("Y: "); Serial.print(event.magnetic.y); Serial.print("  ");
  Serial.print("Z: "); Serial.print(event.magnetic.z); Serial.print("  ");Serial.println("uT");
  /* Display the results (gyrocope values in rad/s) */
  gyro.getEvent(&event);
  Serial.print(F("GYRO  "));
  Serial.print("X: "); Serial.print(event.gyro.x); Serial.print("  ");
  Serial.print("Y: "); Serial.print(event.gyro.y); Serial.print("  ");
  Serial.print("Z: "); Serial.print(event.gyro.z); Serial.print("  ");Serial.println("rad/s ");
  /* Display the pressure sensor results (barometric pressure is measure in hPa) */
  bmp.getEvent(&event);
  if (event.pressure)
    /* Display atmospheric pressure in hPa */
    Serial.print(F("PRESS "));
    Serial.print(event.pressure);
    Serial.print(F(" hPa, "));
    /* Display ambient temperature in C */
    float temperature;
    bmp.getTemperature(&temperature);
    Serial.print(temperature);
    Serial.print(F(" C, "));
    /* Then convert the atmospheric pressure, SLP and temp to altitude    */
    /* Update this next line with the current SLP for better results      */
    float seaLevelPressure = SENSORS_PRESSURE_SEALEVELHPA;
    Serial.print(bmp.pressureToAltitude(seaLevelPressure,
                                        event.pressure,
                                        temperature));
    Serial.println(F(" m"));
  delay(1000);
chunkit
Re: 10 DOF IMU not functioning
by adafruit_support_bill on Wed Nov 25, 2015 8:00 am
Hanging up is often a symptom of an intermittent connection. Please post photos showing your soldering and connections between the IMU and Arduino.
by chunkit on Wed Nov 25, 2015 12:18 pm
chunkit
by adafruit_support_bill on Wed Nov 25, 2015 2:05 pm
The solder looks OK. Make sure that all of your jumper connections are solid. They should be gripped securely by the spring contacts for a good electrical connection.
by chunkit on Wed Nov 25, 2015 2:13 pm
Hi, i supply 5v into the IMU and by using the digital Multimeter to measure the SCL is 4.89V and the SDA is 0.28V.
is the output looks normal or the IMU is spoiled ?
chunkit
by adafruit_support_bill on Wed Nov 25, 2015 2:51 pm
Is this with or without an SDA/SCL connection to the Arduino?
When idle, both SDA and SCL are typically pulled high. Please post a clear close-up photo of the front of the IMU.
by chunkit on Sat Jan 23, 2016 12:58 pm
last time the IMU is functioning well but dunno why now i run the sample code the data is stuck at there cant continue running.
chunkit
by adafruit_support_bill on Sat Jan 23, 2016 2:07 pm
That sounds like a connection problem. Please post a clear close-up photo of the front of the IMU.
by chunkit on Sun Jan 31, 2016 12:00 pm
The IMU got warranty ?
chunkit
by adafruit_support_bill on Sun Jan 31, 2016 1:25 pm
by chunkit on Tue Feb 02, 2016 12:54 pm
chunkit
by chunkit on Tue Feb 02, 2016 12:55 pm
The data is hanging on there
chunkit
by adafruit_support_bill on Tue Feb 02, 2016 1:14 pm
We can try replacing the sensor. Please contact support@adafruit.com with a link to this thread.
