Can the HUZZAH be put into deep sleep mode? According to what I've found online, one of the requirements is hooking up the XPD pin to RESET. Is that pin broken out on the HUZZAH (and HUZZAH Feather) board? I don't see it on the pictures of either chip.
HUZZAH Deep Sleep
- Stagiairdja
Re: HUZZAH Deep Sleep
I have the found on the internet that you need to connect the GPIO16 pin and the RST pin. But i tested it and i get the Adafruit in sleep mode, but then when i pushed the button that i had to get out of the sleep, there didn't happen anything. So i think that there also need to be a resistor between GPIO16 and the RST. But i still need to figure that last out.
- strags
I'm seeing the opposite problem. I've got GPIO16 and RST hooked together (as per the instructions), but system_deep_sleep just returns immediately as if it's not doing anything!
