Adafruit Audio FX Sound Board volume very low
by dkoch7575 on Mon Jan 18, 2016 12:39 pm
Adafruit Audio FX Sound Board product 2133
my first test with the sound board was very loud. Then i soldered the wires to the board secured it to the box and now the volume is very low I can hardly hear it . I tried to reload the audio files , i tried grounding the vol + pin and the reset pin. I do not know if reset took place because the all .ogg files were still there. project remote control hockey goal sound and light
the whole project
whole project.JPG (331.48 KiB) Viewed 476 times
sound card wired in project
pcb wired.JPG (286.97 KiB) Viewed 476 times
soldered side of sound card
back of pcb.JPG (222.93 KiB) Viewed 476 times
dkoch7575
Re: Adafruit Audio FX Sound Board volume very low
by adafruit_support_rick on Tue Jan 19, 2016 1:34 pm
The sound card does not produce an amplified signal. Your problem is probably with your amplifier
by dkoch7575 on Tue Jan 19, 2016 10:29 pm
Im not using an amplifer just an old altec computer speaker. The sound was very good when i first tested it. Now its so low i can barley hear it. If i do need an amp do you sell them with audio jacks
dan
dkoch7575
by adafruit_support_rick on Wed Jan 20, 2016 12:05 pm
Your computer speaker probably has an amplifier built-in. Possibly, that's what has failed.
Do you have some earbuds you can plug into the sound board? That should tell you if it's still working correctly.
If you need an amp, we have several in the store. You would use these with bare speakers, not with your computer speaker.
Stereo amplifiers:
https://www.adafruit.com/products/661?q ... amplifier&
Mono amplifier:
https://www.adafruit.com/products/2130
So you know, 20W is a LOT. I don't know what your application is, but you may not need a 20W amp.
by dkoch7575 on Wed Jan 20, 2016 9:29 pm
I tested the computer speaker and it is good . I tried head set and ear buds still volume so low I can barely hear it . When i first tested the sound board the volume was perfect . Is there a way to test audio output with a scope what should i expect. Can you suggest an amp that i can use powered computer speakers my application is a hockey goal horn .
GOAL HORN https://www.youtube.com/watch?v=A1HdtrbnmyI
dkoch7575
by dkoch7575 on Thu Jan 21, 2016 11:30 am
I brought the sound board to work . I have continuity from the R pin through the jack also tested L pin and Gnd through the jack all good . I do NOT have sound on the R pin . I have sound on the L pin
dkoch7575
by adafruit_support_rick on Thu Jan 21, 2016 11:50 am
Well, let's try replacing it. Please email support@adafruit.com with a link to this thread for a replacement
