ImportError:No Module named Adafruit_DHT
by ryandsouza on Tue Jan 19, 2016 10:17 pm
Getting this error message when trying to run this
https://learn.adafruit.com/dht-humidity ... ll-updated
Testing the Library
To test the Python library you can run some of the example programs in the examples folder. The AdafruitDHT.py example is a simple program which takes from the command line parameters the type of sensor (11, 22, or 2302) and GPIO pin connected to the sensor, and displays a single reading from the sensor.
First navigate to the examples folder by executing:
cd examples
Now to run the example on a Raspberry Pi with an AM2302 sensor connected to GPIO #4, execute:
sudo ./AdafruitDHT.py 2302 4
Make sure to run the command as root with the sudo command as shown above or else the program will fail to run (root access is required for reading and writing the GPIO pins).
ryandsouza
Re: ImportError:No Module named Adafruit_DHT
by adafruit_support_rick on Wed Jan 20, 2016 5:52 am
by ryandsouza on Fri Jan 22, 2016 7:08 pm
Yes I did.
Now when I try sudo ./AdafruitDHT.py 2302 4
I get
Failed to get reading. Try again!
My wiring is correct & I have tried several times, please advise what I need to do to ensure the AM2302 sensor is working?
ryandsouza
by franklin97355 on Sat Jan 23, 2016 1:02 am
Post up pictures of your module and connections.
franklin97355
by ryandsouza on Tue Jan 26, 2016 3:48 pm
As requested, I have added the pictures of the project & wiring.
Let me know if you recommend any wiring changes?
You can also call me at your convenience to discuss?
My cell# 908 912 4160
Thanks Ryan
ryandsouza
by adafruit2 on Wed Jan 27, 2016 6:12 pm
do you have an oscilloscope, that would help deterimine where the signal may be failing
adafruit2
Site Admin
by adafruit_support_rick on Thu Jan 28, 2016 10:06 am
Also, are the wire splices between the sensor and the jumpers soldered, or just twisted?
