Barometric Pressure Sensor DAQ interface Help
by mhoare on Tue Feb 02, 2016 8:24 pm
I am a mechanical engineering student with basic to no knowledge of electronics. I have a NI USB-6259 DAQ device (http://www.ni.com/datasheet/pdf/en/ds-21) and i need to measure barometric pressure with high precision (~ 1 hPa tolerance) I have looked over BMP180 and BMP280 devices and I have found that the communications interface is I2C and SPI which my DAQ device does not have. Is there any way I can connect BMP180 or BMP280 with my DAQ? Are there any high precision barometric pressure sensors with analogue output from adafruit?
Thank you in advance,
Morgan
mhoare
Re: Barometric Pressure Sensor DAQ interface Help
by adafruit_support_bill on Tue Feb 02, 2016 9:56 pm
Freescale makes a range of analog pressure sensors that should interface with your DAQ. I believe it is the MPXV series. The major suppliers such as Mouser & Digi-key should carry them.
by mhoare on Wed Feb 03, 2016 5:34 pm
Thank you for your help Bill, I really appreciate it. I have looked over nxp (I think is freescale) sensors and I couldn't find analog output pressure sensors with the accuracy of BMP180/280. The best accuracy I have found was ~14 hPa which is not enough since I need to measure 1000 to 1010 hPa to the hPa. I seem to only find 1 hPa precision pressure sensors with digital interface.
mhoare
by adafruit_support_bill on Wed Feb 03, 2016 5:50 pm
Have you checked with National Instruments to see if they have any other options? If you are constrained by that DAQ device, you could always do a digital reading and feed the result to DAC. But every conversion will introduce some error and a direct interface is always preferable.
by mhoare on Wed Feb 03, 2016 10:34 pm
Yes I will get in touch with NI support and see how I can interface both devices. Thank you for your help.
Morgan
mhoare
