Burn a bootloader on 32U4 help needed.
by Shayo on Wed Feb 03, 2016 10:54 pm
I've been playing around with arduinos for some time, but never got into burning bootloaders (I always got ones that were already burned).
I recently got the mega32U4 breakout board, and I would like to burn a bootloader that would allow me to upload programs using the arduino IDE.
Can someone please take me through this step by step?
I have an arduino due at hand, and I understand that I should be able to use it as a programmer.
Let's start with these:
1. Which bootloader should I use? where can I download the hex file for it?
2. What is the sequence of steps needed to put the Due in programming mode?
3. How do I tell it to upload a specific hex file?
[FYI, I'm running on osx]
Thank you!
Shay
Shayo
Re: Burn a bootloader on 32U4 help needed.
by Shayo on Wed Feb 03, 2016 11:49 pm
I'll just add this.
I've tried to follow online tutorials, like this one:
http://g11l.com/content/loading-leonard ... 4-breakout
First, it seems like I can't upload the ArduinoISP to the Due.
OK. I switched to Arduino Nano that I had lying around. ISP programmer uploaded.
I then select "Arduino as ISP" for programmer. Keep the same port number I had for the Nano, but change board type to Leonardo. Then I hit Burn Bootloader, and I get this:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x01
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x10
this check.
avrdude: stk500_disable(): unknown response=0x12
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Shayo
by joe3 on Wed Mar 09, 2016 3:34 pm
I am having the exact same issue! Same error line for line.
joe3
