🔮Adafruit sale all weekend long – use the code ADATHX for 15% off! 🔮
No log in
No log in
by JJR222 on Thu Feb 11, 2016 8:37 am
Hi, When I pluged my raspberry in for the first time instead of going to the login like the video shows it goes
rite to a home page with some icons on it and no way for me to do the things the video says to do to load NOOBS from the SD card i Bought. How do I get this thing going?
JJR222
Re: No log in
by adafruit_support_rick on Fri Feb 12, 2016 2:56 pm
That's the NOOBs configuration page. Please see this video:
https://www.raspberrypi.org/help/noobs-setup/
Re: No log in
by JJR222 on Fri Feb 12, 2016 4:40 pm
Watched that video and others this does nothing like any I have seen yet.Some one I spoke with said it sounds like some one already loaded software on it.So that tells me I was sent a machine that some one had a problem with and returned it then I ended up with it.
It goes past every thing on the videos and rite to a screen with a few icons but nothing works except the internet.
JJR222
Re: No log in
by adafruit_support_rick on Sat Feb 13, 2016 10:18 am
please post some screenshots of what you're seeing.
Re: No log in
by franklin97355 on Sat Feb 13, 2016 12:57 pm
There is no software other than the SD card. Everything you see is on the card not on the Pi.
franklin97355
Re: No log in
by JJR222 on Sat Feb 13, 2016 1:47 pm
I thank you very much for the quick reply's.
If that is the case then the Noobs card I bought has a problem every thing I try to open will not open or I
get an error message.
In either case it's not worth the trouble just to run christmas lights ill stick to my laptop I can work that.
Im in the process of sending it back.
Thanks again for your help.
JR
JJR222
